liquid cooling rampage formula?
yeh i just realised but the heatsink layout is exact the same
so i could buy the heatsink from maximus formula SE and put it on mine? because they have the same layout and the maximus has build in water block?
if your not above hacking the coolor to peices, you could just cut off the mosfets portion, and leave those attached to the mobo, and buy an air sb cooler, then use the nb water block i suggested
Probably, but you would need to find a distributor that sells the heatsink from the maximus, not sure how easy that would be to do.
