hello fellas!i look forward to a reply by anyone directing me on how to resolve the problem of d task manager being dis abled and my pc is slow.thankyou
system config windows xp service pack2
504 mb ram
2.0ghz intel centrino .
hi!i downloaded the software but its just poping up and is just emphasizing i should purchase the full version.what is u next line of advice pls.
HDD-SATA
RAM- 512mb
DDR2 MEMORY
INTELCELERON @2.0GHZ
WINXPhome edition service pk 2.
not sure of policy about this. I visit a few sites and know some of them. a couple days ago i seen the same question if you would like to try his results that worked for someone else then here it is.
Click Start
Click Run
Enter gpedit.msc in the Open box and click OK
In the Group Policy settings window
Select User Configuration
Select Administrative Templates
Select System
Select Ctrl+Alt+Delete options
Double-click the Remove Task Manager option
You can now change the way task manager works
You should also scan your computer for viruses and spyware
This usually only happens after a spyware infection
