deffinately. not worth the transfer over by anymeans, but its noticable.
Thx, I was planning on buying a 1080p monitor with an HDMI inputDoes my motherboard need to support HDMI?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009163
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236052
Which would you choose?
Also- How do I replace URL links with a single word? I used to know but I havent used it in a while so I forgot. Many thanks!
I'm sure the Acer is a matte finish. If it were glossy, they'd definitely let you know.
here is an ASUS that is cheaper than the acer but pretty much the samething. only its a 21.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
i have this monitor and have had no problems with it and am very happy with it![]()
but would the 2 inches be that noticeable?
1080p on a 22inch monitor is hardcore and really not worth the upgrade unless you have the extra monezs to spare.
Oh btw a DVI to HDMI convertor has less colour range, and sharpness to it, so if you can try get a video card with an HDMI output and use only that, otherwise you might be dissapointed in your results.
