So, I've been contemplating buying like 1GB more of RAM for my computer.....if it will even make much of a difference?
Here's my current specs:
AND Athlon 65 3500+
Geforce 7600 GT 256 MB
1024MB RAM
I'm just not sure what will be compatible and give me the best performance with my current motherboard and RAM cards.
My motherboard is an Asus A8V Deluxe.
Maximum Memory Capacity: 4096MB
Currently Installed Memory: 1GB
Available Memory Slots: 2
Number of Banks: 4
Dual Channel Support: Yes
CPU Manufacturer: AuthenticAMD
CPU Family: AMD Athlon(tm) 64 Processor 3500+ Model 15, Stepping 0
CPU Speed: 2202 MHz
I currently have two 512 MB Corsair DDR (PC3200) sticks:
Speed: 200 MHz
Memory timings: 2-3-3-8-0 at 200 MHz, at 2.5 volts
Data width: 64 bits
EPP SPD Support: No
XMP SPD Support: NO
I'm considering just buying one or two of these sticks, will buying the same brand help?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145026
Any recommendations? Links? etc...?
AND Athlon 65 3500+
1024MB RAM
Number of Banks: 4
CPU Speed: 2202 MHz
Speed: 200 MHz
Data width: 64 bits
EPP SPD Support: No
XMP SPD Support: NO
