Computer keeps restarting
Membrillo69
Hey guys, I uninstalled the drivers to my old graphics card, so I could install my new one..but when I tried restarting it gets past the Windows Xp screen and then just Turns off and on real quick..every single time. Can anyone help me out with this?
This happened to me before but on a different situation because when i installed my webcam on my old pc, the graphics were not good so it kept restarting my pc, so i updated the graphics card, and now it stops restarting!
- Your problem is your graphics card/Adapter.
Well I know it has something to do with removing my graphics card Drivers. Because as soon as i did it it kept the restarting thing..I dont know i tried system recovery and now it is stuck in that..what can i do?
It looks like Windows has not finished the Job of uninstalling. Hi if you have taken your old graphics card out, I suggest putting it back in. Then try again, make sure you remove the drivers from both add and remove programs and the device manager...
I hope this helps.
