It's August on their site I think.
Luckily, they don't let people download them anymore.
Go to start and type in "winver"
It will tell you how long until it expires.
If you have build 7000, it likely expires on 8/1/09. Well mine does atleast.
you can still get it though im sure.
From an MSDN convention, no more scheduled though.Wow, you actually have the DVD from MS... how'd you get that?
b. Time-Sensitive Software. The software will stop running on August 1, 2009. You may not receive any other notice. You may not be able to access data used with the software when it stops running.
Hmm, did your download come with a terms of service agreement? Mine did, and here is a quote from it.
Also, you must activate it within 30 days of installing, or you will have to reinstall it. After you have the key, it should last until the time-sensitive date.Code:b. Time-Sensitive Software. The software will stop running on August 1, 2009. You may not receive any other notice. You may not be able to access data used with the software when it stops running.
