dsolash New Member Mar 6, 2009 #1 Water cooling for my pc? Hi i would like to get my Phenom 9950 125w saftley to atleast 3.6. I would like water cooling, and spend under $350. If this is not possible, any other kind of cooling that can achieve this for under $350 will do. Last edited: Mar 10, 2009
dsolash New Member Mar 6, 2009 #3 those coolers are not as good.... the 120 ex is the best air cooler on the market...
Z zer0_c00l Active Member Mar 6, 2009 #4 Xigmatek Dark Knight keeps my cpu 20/22c idle 28/30c 100% Load 0% load 3.4 ghz stays the same with no voltage bump 100% load 5min Last edited: Mar 6, 2009
dsolash New Member Mar 6, 2009 #6 zer0_c00l said: Xigmatek Dark Knight keeps my cpu 20/22c idle 28/30c 100% Load 0% load 3.4 ghz stays the same with no voltage bump 100% load 5min Click to expand... #1. That is a phenom II which runs cooler. #2. Its a triple core so it produces less heat.
dsolash New Member Mar 8, 2009 #8 mep916 said: http://www.computerforum.com/1187936-post1.html Click to expand... Still not better thanks for the help though guys. Any other suggestions?
