Dr. Dockter
Do motherboards differ a lot in how much heat they produce? If they do, how can you then know which is which?
The mainboards don't draw that much current. It is the processor and video cards that take most of that. Mainboard heating is roughly meaningless.
It isn't the board that draws the current. It is the processor. And it is the processor that generates the heat because of it. The board is just the conductor, not the sink. Same thing as a toaster. The toaster gets hot but the wire connecting it to the outlet only warms up because it is near the heat source. It doesn't draw current itself.
Love the memory cooler.
The pcb (board) does actually function as a heatsink. (for the little resistors and capacitors ert on the board. )
also, wires get warm when the current, in relation to the thickness, is big enough. (not as in instantly frying, but conductors do get warm, they have a resistance, so the do dissipate heat.
