If i get this processor...does that mean i'm stuck with the 32 bit vista and 4GB RAM without overclocking? Or is it all up to the motherboard?
By the way, what's the main difference between the motherboard and the processor? To take a stab at it, i'm going to say the motherboard houses all the computer's information and the processor fuels the motherboard??
no, you can go to 64 bit vista, along with 16gb's of ram(if the board were to support it, vista can actually support 128gb's) and the motherboard basically just houses everything, and basically makes them talk to each other, and the processor processes data
more people are just buying quad cores now, as far as the motherboard depends what you're looking for this one might have more usb ports etc, make sure your motherboard supports your cpu too.
Windows Vista Ultimate supports 128 gigabytes of RAM
Windows Vista Enterprise supports 128 gigabytes of RAM
Windows Vista Business supports 128 gigabytes of RAM
Windows Vista Home Premium supports 16 gigabytes of RAM
Windows Vista Home Basic supports 8 gigabytes of RAM
And Windows Vista Home Basic 32-bit supports up to 4 gigabytes of RAM
I made the purchase of the processor, but I'm still browsing motherboards. I don't make much money so this is going to be a long process. I don't need a motherboard with many usb ports 4 are good enough.
was it an oem or retail processor? should make a new topic with what youve bought and what youre looking for im sure people will help you pick parts, post links too makes it easier
I would advise you to not purchase any more parts until you are ready to purchase them all. You don't want to buy a component and find out it is defective 30 days down the road and be unable to return it.
One component you do not want to go cheap on is a motherboard. It is one of the most important components in a personal computer.
Overclocks like a dream and it has room for a Tuniq Tower 120 and Xigmatek S1283 cooler which some motherboards have issues with such large after market coolers.
The ram above was ok but its not free shipping so you spend 8-9 bucks for almost the same.
You can also overclock this ram to 1066mhz @ 5-5-5-15 or leave it at 800mhz and 4-4-4-12. Some have achieved 4-4-4-12 1066mhz but 2.0 volts is to much for me.
I also agree you shouldn't buy parts unless its all at once. Nothing worse then a DOA after 30 day is up.
