Computer newbie needs help in buying a pc
namkim85
LINKS MAY NOT WORK LOOK FOR SPECS ON 4TH POST
Hi, right now i'm debating whether i should buy http://www.newegg.com/Product/Produc...82E16883227125
and add a http://www.newegg.com/Product/Produc...82E16814102768 (ATI radeon 4870x2) and crossfire the 2. (i'm curious.. will the watts on this powersupply even be enough to crossfire the 2?)
or whether i should buy http://www.newegg.com/Product/Produc...82E16883227126
or whether i should buy http://www.newegg.com/Product/Produc...82E16883227135.
The only reason i'm thinking of buying the third option is 12mb cache (i dont even know what that really is and i'm not too computer literate in this sense, but i just hear its important from a friend).
Which is the best bang for my buck for gaming? 1400 is my budget
I'm planning to hook it up to my HDTV and use that as my monitor btw as my setup.
Thank you so much in advance.
its strange that the links arent working...
well for the specs for the 1st one -900$ and 300$ for vid card
Processor AMD Phenom II X4 920(2.8GHz)
Processor Main Features 64 bit Quad-Core Processor
Cache Per Processor 4 x 512KB L2 Cache
Memory 4GB DDR2
Hard Drive 500GB SATAII
Graphics ATI Radeon HD 4850 512MB
Power Supply 580W
Chipset AMD 790X
L2 Cache Per CPU 4 x 512KB
L3 Cache Per CPU 6MB
PCI Slots (Available/Total) 2 x PCI-Express x16
1 x PCI-Express x1
2 x PCI
(Adding ATI radeon 4870x2 by crossfire)
THE second one is 1300$
Processor AMD Phenom II X4 940(3.0GHz)
Memory 8GB DDR2
Hard Drive 1TB SATAII
Graphics ATI Radeon HD 4870 1GB
Power Supply 680 Watt Power Supply
Chipset AMD 790X
External Bays 5 x external 5.25" drive bays
2 x external 3.5" drive bays
Internal Bays 3 x internal 3.5" drive bays
1 x PCI-Express x1
2 x PCI
the THIRD one is
1380$
Processor Intel Core 2 Quad Q9550(2.83GHz)
Cache Per Processor 12MB L2 Cache
Memory 8GB DDR2 800
Graphics NVIDIA GeForce GTX 260 896MB Video Card
Power Supply 800W
Chipset NVIDIA nForce 750i SLI
CPU FSB 1333MHz
L2 Cache Per CPU 12MB
2 x PCI-Express x1
2 x PCI
