Fan Problems (concerning 3/4 pin connectors)
Parsnip
Hi
I recently built a gaming PC with 3 fans for cooling - one 120mm at the front, one 120mm at the back, and one 120mm fan blowing over a Scythe Ninja.
The problem is, my mobo (Asus M3N78-EMH HFMI) only has one 3-pin fan connector. This leads to two problems:
1. I can only have one fan running (naturally I hooked up the CPU cooler).
2. I get a boot error - No CPU fan detected!
Is there a way of getting a 3-pin 120mm fan running off a 4-pin CPU fan mobo connector?
I could live with 2 out of 3 fans.
Thanks in advance for your help
You should be able to just put the 3 pin fan in the 4 pin connector with 1 pin unused, the fan will still spin but will not be speed controlled by temperature like a CPU fan
Plug your remaining fans directly into your power supply.
To do this you must buy adapters. They are really cheap £1 or so (in theory about $0.70). They basically plug into one of you 4 pin molex adapters and splits to another 4 pin molex (so you lose nothing) and a 3 pin fan adapter, like the ones on your mobo
Sounds great, what are they called? (So I can search for them easily).
And I'm UK so it would be £1 (or w/e it costs). I'll have a look on Ebuyer, or go to me local PC shop.
I have just found this, i didn;t know they made em, but here we go
http://www.valuemedia.co.uk/popprods.htm?Product=TX3SPLITTER
That is purely for price, i couldn't find a seller with picture (google for picture), but i will explain now:
It is a 3 pin fan splitter, so it goes into your fan socket on your keybaord and splits to 2 seperate fan cockets, so you can have 2 fans off of 1 socket. Now, how useful this would be, i don't know because you need 3 fans off the 1.
for the molex ones:
http://coolpc.com/Mini-34-pin-fan-a...tm_medium=organic&utm_source=froogle-GB&id=uk
http://www.revealcable.co.uk/acatalog/Powercables.html#aAA2117
the second one is from a UK site, so shipping will probably be cheaper. It is the 7th one down on that link, Power splitter 5 1/4" male to female and 3 pin case fan is what it's called.
Not sure if this helps but the picture I found of the board shows 2 fan connectors,
not just one. Although you would know better if does or not. I realize you'd still be
one short, but also one closer to your goal. =D
This is a screen shot of the model board you listed.
