dude if your gonna spend 3 gs on a gaming rig than you better know that you should be using at least vista ultimate 64. Or wait until seven comes out. I have been using the beta seven version and it is pretty sweet. I t uses direct x 11. With all that top notch hardware you are going to be using you better believe the operating system will make do for you through the upcoming years.
Im getting so far:
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365 -
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145232
Video card x2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143167
Hard drive 1
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136322
Hard Drive 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
DVD Burner x2
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106287
After market cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029 -
Programming System
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116493
The things i might be changing are the cooling system since it has bad reviews and getting tivo instead of a tv in my room and depending on when it comes out the new evga x58 board and the vista ultimate 7 if it really makes that much of a diff.
I'm moving and my mom says i can have 3000$ to spend on a computer but i cant get it till we actually move, we have a place picked but we do not have a precise date on when we will be moving in but when we do im going to order the parts on that exact day so if those new parts arnt out yet i will just stay with what i got
