buying new parts
joelmagar
i have vista right now, but once i get a new motherboard, will i be able to reuse that copy of vista with the same key or am i going to have to get a new copy?
If you bought the full version and not the OEM version, then yes you will be able to use it on a new computer after deactivating it on the first pc.
i dont think it's oem, i bought it straight from best buy and it doesn't say OEM like when you buy it from Newegg
