Hi all..
I m looking to buy a laptop(personal use only) preferable a macbook near abt $1500 ...
Plz suggest the best buy in this range (apple or any other company). Any sales on apple laptops anywhere in us.
As far as APPLE goes you aren't gonna see any sales really, besides their little ones they offer once in a while.
However, like others have said, you can buy an Acer, HP, Dell, and get more bang for your buck. If you want to go with some direct savings try Newegg.
Why get Apple Products when they cost the earth?
You could get a cool new laptop for a decent price and STILL save a ton of money to buy anything else such as accessories![]()
Well, if you must get a Mac laptop, get a Pro.
But, you can get a cheaper laptop with similar specs
for much less.
Apple's way too overpriced, then you have to fight with
their OS to install programs you want. Not worth it IMO.
wats the OS used in apple?.. and which company would u suggest in this range?.. plz do mention the models if u can.....
do reply quick. i have to make a choice by tomorrow.
for much less.
I would second that, but for under $1500, the MacBooks are not horrible.
Also true. I would also emphasize "cheaper", because in many cases - not all - you will not get the same build quality that you would with an Apple.
Debatable with spec vs design as far as cost is concerned, but this is highly subjective. You will pay a premium for Apple products.
I am curious about the "fight with the OS to install programs you want" part though. Have you had such a struggle with installing applications on OSX in the past?![]()
Yes, on OSX you can install Boot Camp, which will allow you tocan we install ne other os linux may be
plz list out some models of apple u would suggest...
install Windows on it, but what's the point in spending all that
money for a Mac, only to put Windows on it?
Just get a Non-Mac laptop, with the fastest CPU, most RAM,
and best GPU you can afford.
i see most of u do not suggest apple...
i m actually going for looks and reliable performance and a good battery backup.. no gaming but i yes i would need to use some softwares i m using on windows right now.
if you want a laptop to run windows programmes on then a windows laptop would be your best bet!
Whats wrong with hp and acer. If you don't want to go with either of those brands i'd suggest a dell.
What's your price range?
