Bodaggit23
I can't see any reason to go back to 32bit.
If you run less than 4Gigs of RAM, you don't need 64bit.
So reading this thread - is it a safe conclusion to make that any new system built should be 64 bit.
More memory / faster speed
Is there any downside to 64 bit that one would choose 32 bit?
Nicely put, good to know stuff.
So am I the rare one using a Windows Vista 32-bit operating system on this forum?
I have no plans to upgrade my operating system until 3.25 gigabytes of RAM is holding my computer back (which won't be for a few years).
how would you know if your running 32bit or 64bit?
You could also find your Run dialog and type in:how would you know if your running 32bit or 64bit?
Well technically if you use a 3d modeling software or something of that manor then you'd probably want over 3.25 gigs.![]()
Is there anyone who got windows XP 64bit?
.Is there anyone who got windows XP 64bit?
We run XP 64bit at work exclusively.
We run Pro/Engineer CAD/CAM modeling and programming for our CNC's.Just curious - what do you do that requires XP64?
Computer Numeric Control. They are 3 Axis Milling machines that make parts for automated packaging equipment. You basically feed these machines lines of code and they'll cut out just about any shape you want.What is CNC are you an architecture?
Which is better XP or Vista? on a 64bit
Vista x64 will obviously have all the features of Vista, and XPx64 will have all the features of Vista. They use the same 64 bit technology so it's up to you.
