Ok I want to have a red theme
and I found some Red fans that have 4 pin connectors
http://www.newegg.com/Product/ShowImage.aspx?CurImage=11-998-123-04.jpg&Image=11-998-123-05.jpg%2c11-998-123-04.jpg&S7ImageFlag=0&WaterMark=1&Item=N82E16811998123&Depa=0&Description=APEVIA%20CF12SL-URED%20Red%20LED%20Case%20Fan
GRR!! Lol i need to learn all the connection names seriously
Ok I found some Fans that say 3/4 pin
Rosewill RFA-120-RL 120mm 4 Red LEDs LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200050
Fan controller http://www.newegg.com/Product/Product.aspx?Item=N82E16811999171
And is the 200mm fan ontop of the Antec 1200 blue LED? or no
Maybe I should Go with different case
Would this look good?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133056
that looks good. the fans have 3 to 4 pin converters. so you should have the right connector. if you finally get everything and you dont have the right adapter, you might as well get some converters from newegg.
the big 200 mm fan in both the antec 900 and 1200 has no leds in it.
oh. does the 900 not have leds then?
