im looking for a cheap motherboard that has firewire. it can be am2 or 775. cheap is the number one factor.
[-0MEGA-];1217345 said:You could also get a cheap PCI firewire add-on card.
if you have a laptop or dont have any spare PCI slots then this could work. http://www.newegg.com/Product/Product.aspx?Item=N82E16817111714
It may not be as fast as a PCI card but it will work when you cant use one.
This is just a hub. It does not give you the capability of those ports. I just extends from what is already available in the computer.
OK - I'm showing my greenness here -
But,
I thought a firewall was a computer application? How exactly do motherboards have firewalls - are they embedded into the hardware - OR - is there something more that I don't understand about firewalls?
How common are firewalls in MOBOs.
Trying to sponge any knowledge I can
Thanks
Really? oh, well that sucks.
Deleted the comment to avoid confusion.
The confusion lies in the terms
you are thinking Firewall
we are discussing Firewire
Firewire is like USB, except different
A firewall protects your computer from network threats.
Well Firewire was created in 1995, so it's not really anything new.Thanks
The newness of all these computer jargon caused me to misread the OP.
[-0MEGA-];1218058 said:Well Firewire was created in 1995, so it's not really anything new.![]()
