The use of built in video cards = lower motherboard durability?
ecyor07
Hi, I bought a new motherboard (MSI K9N6PGM2 - V). I know that its not a high end motherboard because its a little cheaper than other mobos. The built in video card chipset is GeForce 6100. My questions are:
1. Is it ok if I use the built in video card for gaming?
Games are: Left4Dead, Rohan Online, Silkroad Online
2. If I will use the built in video card for a long period of time, will this affect the stability and durability of the motherboard?
I need your opinions guys. Thanks.
That will not run left4dead well guranteed. And to my experience using onboard graphics does not affect the life/durability of the mobo
I've run BF2142 with that chipset and it was miserable.
It was playable, but only on smaller servers.
I've never played any other games without a video card
on that system.
The onboard is just to get you by basically. The only way
to know is to try. If it runs your games at an acceptable
level for you, then go for it.
It's not going to hurt anything.
