Alright well i have downloadede everest but cant for the life of me find where the psu area on it is, could you lend me a hand finding it please?
==EDIT==
I've found it, but it doesn't show the -12V reading at all nor the 12V because it says it is only a trial, which it is
unfortunately not, that is why i was going off speedfan.
i think i should point out though that all of the readons on everest are the same on speedfan because they work off the same sensors, so speedfan will have the exact same as everest
Well, i know that speedfan was showing my +12v rail at 11.18v when my dmm and everest both showed +12.1x Volts, so im not sure what was up with that. Like i said before though, more than likely its just fine....
You can double check it with PC Wizard and Sandra Lite.
http://www.cpuid.com/pcwizard.php
http://www.sisoftware.net/index.html?dir=dload&location=sware_dl_3264&langx=en&a=
Software is dodgy at the best of times to measure your voltages. Based on the above I would disregard the whole lot. Get a multimeter and test the individual rails under load. This is the ONLY way to be conclusive about such measurements.
BTW, what psu do you have?
Corsair TX850. That is why i was surprised to see it so far out (if it is out that is)
