you could set up the a computer in the bar
I wouldnt set the computer up in the bar incase you never know someone may notice it and unplug the camera or possibly steal it.
Even if they were to do a robbery in such case, they may mess around with the electrics or things in the club.
Heres what i find:
Luxriot Network IP Camera Software
LuxRiot is a Digital Video Recording and Remote Surveillance software package for the Windows based PC.
LuxRiot offers principally new concept of DVR solutions – “One Software/Choice of Hardware”. This choice of hardware is not limited to different video capture cards with varying Frames-per-second rates and number of inputs. The choice is much greater: in addition to supported video capture boards, you can use many Network IP cameras from major manufacturers, Network IP Video servers, as well as any DirectShow compatible devices such as multichannel videograbbers, USB cameras, and camcorders.
LuxRiot has 5 different editions to better suit our customers' needs and budgets. Ranging from Personal to Enterprise, they vary in number of allowed camera and remote client connections, as well as some features, but all have the same user-friendly interface and upgradeable from lower to higher edition. Read more about available Editions
User-friendly interface makes the most advanced surveillance features easy to use and understand. All commonly used operations can be performed via intuitive wizards.
LuxRiot is fully equipped with the full set of advanced surveillance features. Visit our Features Page for detailed explanation of all LuxRiot can do.
» Standard Surveillance Features:
Continuous recording. Recording will be running 24/7.
Multiple screen configuration options.
Motion Detection.
Remote connection via Internet and/or LAN. Server can be accessed from any part of the world for remote monitoring, video playback, user management and more...
Real-time playback without interrupting recording. Any camera can be played back using Client application locally or remotely. Such playback will not interrupt ongoing video recording, nor the quality of the recording will be compromised.
» Advanced Surveillance Features:
User-friendly wizards make LuxRiot easy to use and configure. All commonly used operations, such as adding access to a new Server from Client application, searching for Network (IP) cameras, user management, etc. can all be performed via intuitive wizards. This helps make very advanced features accessible to an average computer user.
User Management controls access to cameras and program features. Depending on user status, s/he can be either allowed or denied to perform the following operations: access archive, administer server, connect locally and connect remotely
Control PTZ cameras. Pan, tilt and zoom cameras can be fully controlled from within the Client application.
Multiple clients can be connected to a single server. Depending on edition and user management settings, 1 to unlimited number of local and remote client applications may access the server to receive live and recorder video, as well as perform other operations
Client can be connected to multiple servers simultaneously. A client application user, if granted sufficient privileges, can connect to unlimited number of servers to view live or recorded video as well as perform other operations.
Each camera is individually configurable, including: recording, motion detection, image adjustments (brightness, contrast, sharpness, hue, saturation) and more
