Is there any way to save D/L apps with a windows reinstall
Jamin43
banned
I want to do a windows re-install on my backup computer - but it's got a few apps that I downloaded online for free a while back - that are no longer available.
* A microphone recording application
* AceHTML 6 a web page development app that will cost me 80 bucks to download today.
* Nutrition application for my palm pilot
* a few others that I'd like to keep but not super important.
I think the answer is " no " but is there anyway I can save these apps onto a disk to reinstall after a windows re-install.
You can backup your whole install if you have the right software.
Google some backup programs. You might find a free one.
Keep in mind, I set mine to do a full system backup and it said it
would take 12-16 CD's. lol
If I backed up the whole install - wouldn't I defeat the purpose of re-installing Windows XP.
I wanted to re-install windows to get all the unneeded junk from my computer - from 5 years of using Windows - and all the accumulated files that come along with using a PC for that period of time.
And To get rid of some of the pre-installed Dell software that clogs up the startup and slows the entire system. Right now - My primary PC is a DELL PC I got as a hand me down - I upgraded to 2GB RAM and reloaded everything. It's working better than when it was new.
My other PC - originally came with a 20gb hard drive that I added some RAM and 160GB hard drive as a slave drive. I'd like to get rid of the 20 gb drive alltogether and install everything Windows XP + applications + files ( minus the non-used applications ) onto the 160 gb drive.
Could your backup scenario help in this work through - or not?
Yeah, sorry for the suggestion. Just trying to help. :rolleyes:
Anyway, try this:
Find the install folder for the apps you want to save.
Copy the Enire folder to another location, say a USB drive or what have you.
Try to run the application from the USB drive by finding the .exe
If you can run it from the new location, you've just backed it up, and can
reinstall and put it back where ever you want.
Some programs will run straight out of their install folder like this.
It's worth a shot.
Thanks alot. Sorry if the tone got misread - nothing but appreciation from any suggestions I get. Was just trying to clarify.
That program install idea sounds like a good one - I'll definitely give it a try.
Thanks
