Firefox Addons Thread
Not sure what has been said so far, not going through, but ehre are what i have so far (appolgies if they have been said already):
Red Shift V3 Theme. I like how it is black and red (+1) ant that it doesn't complicate things, it keeps it all very simple, i can't stand buttons i don't use (+2)
Google Toolbar. Again, it is so i don't have to keep going home when i need to search for something, it is again for the over complicating thing i said before in the red shift theme.
And that is it, can't be doing with finding all the stuff which on paper looks incredibly useful, but that will never get used
Added;)
maybe a brief description next to each link, just a few words about what it does.
Will do... Tomorrow when i get some time, if anyone wants to send me a pm with a list of descriptions for each one currently there though i would appreciate it much;)
Here's the ones I use
Adblock Plus
Anycolor
Download Helper
Fission
Foxtab
Speed Dial
Stylish
WebMail Notifier
Here's one for the photography buffs around here.
https://addons.mozilla.org/en-US/firefox/addon/5673
It is so you can see the exif data of an image in the browser instead of having to download it then opening in lightroom or some other program. Tells you basically everything there was done in camera to make the shot as long as the user left the exif intact when uploading the image to the net.
here are my favs. may already be mentioned but loo lazy to check:
no script - self explanatory
addblock plus - obviously
download status bar - keeps things neat
boss key - minimize to tray
download helper - downloading embedded flash files
full full screen - for a large view when needed. the best if you know keyboard shortcuts
snap links - to open multiple pages at once
bazzacuda image saver - to save images from tabs
febe - to back up your addons/extensions
Adblock Plus
Anycolor
Download Helper
Fission
Foxtab
Speed Dial
Stylish
WebMail Notifier
Added ones that werent duplicates.
Added
Added non duplicates;)
By the way, to everyone posting addons could you please check the list up at top of 1st page, makes it easier to add new ones to list;)
ive added some more addons
searchbar autosizer
peers - shows you searches from google and other sites as you type in the url box or the google seachbar
smart bookmarks bar - hides the text of your bookmarks until mouseover
just wanted to add that with tab mix plus, you can turn on a setting that allows you to change your tabs by mousing over them.
searchbar autosizer
Added;)
Vista-Aero is a great theme.
Use Glasser addon and you get the clear background IE8 look. - Works only on Vista and Win 7. No XP support.
glasser only works with the new beta of firefox.
Under the grey'd out Add to Firefox button. There is a link that says "older version". Click on that and find the most updated one you can install.
Also,
Compact Menu 2 hides the menu bar so it simulates IE8 to a further extent.
Also,
apparently, glasser doesnt like any other tab addons, since it only skinned my top bar, and not the tabs bar. and, it didnt skin the title bar, which i think is because of windows 7.
stop autoplay - great for websites that has a bunch of flash/audio you don't want playing all at once. if you do want to play a file just click on the icon on the page
united states english dictionary - spellcheck
