uverse
goto connections manager xp or vista, and enable lan. If your hardwired. If your wireless, goto services under the administrative tool and make sure the wireless zero config is started. then locate the network using windows to connect, not the 2wire wireless manager. Also you will know if you have connection with the att RG or modem if the green light where you plug the lan into is lit up in the back of the gateway. (not the local ethernet light on the front)
