Lost onboard sound
mikedeuk
After a fresh install on my sisters computer i seem to have lost the driver for onboard sound!
Ive tried to download it from the manuftrs website but still no joy! :(
Its a foxxconn RC4107MA, Whats the easiest way to fix this?
Go into the BIOS settings and under intergrated components, check if the onboard audio is enabled. Sometimes if you reinstall, your BIOS Drivers will be reset and you would have to go and fix it in the BIOS. Hope this fixes our problem.
Thanks for the help but there was no such option.
It appears the link doesn't keep the settings.
Choose Motherboards, then choose Socket 775 for Series, then find those board numbers way at the bottom of the list.
Is this the page you were at for the Audio drivers?
Yes Thanks, i have now downloaded the correct driver and after working out how to extract and install it my sound now seems to be working again!
Thanks alot :good:
