screwgravity03
Hey everyone, I'm new to the forums and looking for some input on a new i7 comptuer I'm building. The computer will be for documents (college stuff), burning dvd's, photoshop, minimal video editing, internet, some gaming, the usual. My budget for this is $2000-2500 (Canadian $) but I'm trying to stay as close to $2000 (with shipping/handling) as possible. I think I've got bascially all the parts I need picked out, just looking for some help to make sure I didn't make any mistakes or overlook any better options. This is what I have so far:
Processor = Intel i7 920 - http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202
Motherboard = Asus P6T Deluxe - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131351
Graphics Card = GTX 260 Core 216 Superclocked - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130433
Memory = OCZ Platinum 6GB (DDR3) - http://www.newegg.ca/Product/Produc...NEFL040809CA-_-DesktopMemory-_-L0A-_-20227381
Harddrive = Seagate Barracuda 500GB (getting two) - http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148395
Power Supply = Corsair CMPSU 750TX (750W) - http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006
DVD Drive = Samsung CD/DVD Burner - http://www.newegg.ca/Product/Product.aspx?Item=N82E16827151173
Case = Thermtake ArmorPlus VH6000BWS - http://www.newegg.ca/Product/Product.aspx?Item=N82E16811133056
Keyboard = OCZ Alchemy Series Elixir - http://www.ocztechnology.com/products/ocz_peripherals/ocz_alchemy_series_elixir_keyboard
Speakers = Logitech 2.1 Multimedia Speakers - http://www.newegg.ca/Product/Product.aspx?Item=N82E16836121014CVF
OS = 64 Bit Vista - http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116488CVF
For a mouse I already have the Logitech MX518 Gaming Mouse. Also, the Case, Processor, Operating System, Harddrive, Speakers, and Keyboard I'll be getting locally because its cheaper. So that local stuff, plus the Motherboard, Graphics Card, Memory, Power Supply, and CD/DVD Drive from Newegg come out to $2,065, $2,025 with rebates (includng shipping/handling). If you could just go over the list and check that everything looks right and that I haven't overlooked any other better parts, while keeping the budget in mind, I'd really appriciate it. If you do think something should be changed, try to use the Canadian portion of Newegg to link it (http://www.newegg.ca/). Thanks in advance and I look forward to reading your input.
