I need a suggestion for a GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161252
That'll get it done, better for the price of the card you found.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131125
If you don't want to spend too much, but want significantly better framerates, the 4850 is your girl.
This particular one is $130 + shipping ( i wouldn't put much faith in rebates, their hit and miss)... but it doesn't come with a crossfire cable, and the fan is reportedly loud. 4850's are great, but I'd suggest getting a different variation of it if you want a more quiet fan, or crossfire.
I'm also selling my 4850 for $105 shipped if you'r einterested :P
The 4870 is an all around solid card, but at a bit more of a tag, http://www.newegg.com/Product/Product.aspx?Item=N82E16814102834 Great card, but it's $160.
yepp.
I want to play crysis, dirt, COD4 and 5, asnd... thats about it. But I want it to work with better games if I choose more demanding games. Can anyone make a suggestion for what i should get? im looking at this but have no experience with GPUs. (its my first build)
The card you choose depends on your system specs.
No need getting a high end card if you have an older system.
Please list your specs, then we can look at cards.
Btw, there's not much out there, if any, more demanding than Crysis.
