Any advice on my first computer build is appreciated
ShaunQN
I am going to build my first computer and was wondering if anyone saw any complications or needed upgrades. I am looking at spending right at $800 for the build. Here are the specs.
CPU - Intel i7 920 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Motherboard - MSI X58 Pro LGA 1366 Intel X58 ATX Intel Motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813130221R
RAM - CORSAIR XMS3 3GB (3 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple Channel http://www.newegg.com/Product/Product.aspx?Item=N82E16820145221
PSU - OCZ StealthXStream OCZ600SXS 600W ATX12V / EPS12V SLI Ready Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
CD/DVD - SAMSUNG 22X DVD±R DVD Burner with LightScribe Black SATA Model SH-S223Q http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
HD - Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Graphics - BFG Tech BFGE96512GTOCBE GeForce 9600 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI http://www.newegg.com/Product/Product.aspx?Item=N82E16814143161
Any thoughts??
What is the computer going to used for?
Just a recommendation...you could go with a LGA 775 socket quad and save money. Then you could put the extra money into other parts.
I would say the GPU is a bit weak. But you could always get a better one when you get cash.
RAM: Go for 3 x 2GB for $85
Man, that's dirt cheap for a 1366 mobo.
BUT: Keep in mind the Open Box Motherboard will not come with any cables to connect your drives.
+1 on the 6Gig RAM suggestion, unless you're not using a 64bit OS.
Nor will it come with anything else, such as the rear i/o panel or driver cd's. Plus with open box products there is always the chance there is somethin wrong with it...
Thanks for telling me about the no cables and drivers thing. i didn't realize thats what that meant. If I don't do the open box it drives my price up a little too high. What would you guys suggest for a $800 machine. The computer will be used more for general school stuff and the occasional game or two but I also want a computer that will keep up with technology.
The graphics card is something I was going to upgrade in the future. I guess I could just install my GeForce 7900GS for now and use the extra money for the motherboard. What do ya think??
Drop 9600GT
Get the cheap GIGABYTE GA-EX58-UD3R...
Upgrade to a higher end video card in future.
Sounds to me like you don't need an i7 system.
I'm pretty sure you could build a killer Core 2 Quad system for $800.00.
