Where to plug in power for video card on motherboard 0fm586
PlayerOne
Where to plug in SPDIF for video card on motherboard 0fm586
I am installing a GeForce 9500GT on my Dell Inspiron with 0fm586 motherboard, but I can't seem to find where to plug in the power for my video card.
Can someone please direct me?
Will my factory PSU suffice or do I need another PSU? I have another from a while ago, a rosewill RP650-2 650W, do I need to use this?
Thanks in advance!!!
The power for your video card comes directly from your psu. Check the specs of the card for requirements.
sorry it turns out it's not a power supply cable, it says SPDIF
do I plug this into the mobo? I heard the seller say something it has to do with sound, but I don't have a dedicated internal sound card, so where do I plug this in?
SPDIF is only for sound. It looks to be used when you use a DVI to HDMI converter. However, not too sure where it connects to that card...
But you basically connect it to an outside source, like a center receiver for a home theater.
Which version of the 9500GT did you get, meaning which maker? The SPDIF connector is for running HD sound and it plugs into your motherboard if you have a SPDIF connector on it.
