Dominators or Reapers?
Which set?
  • OCZ Reapers
    Votes: 4 22.2%
  • Corsair Dominators
    Votes: 14 77.8%
  • Total voters
    18
Kornowski
Both 1066Mhz OCZ Reapers and Corsair Dominators are the same price. Don't know which one to go for though?
Corsair, my luck with ocz hasnt been the greatest. Just to run the stock speeds/timings on my ddr3 i have to run 1.9v instead of regular 1.7v...And its not defective ram either... just doesnt like nvidia chipsets for some reason. The ocz ddr2 though is alright, but i prefer corsair.
Corsair Dominators for aesthetics, performance difference between the 2 is probably minimal. It's just that the Reapers are **** ugly.
I think the Reapers look sexy, might be just me.
Either way you go will be a nice upgrade. I don't think there's a difference at all between the two as far as performance goes. Go for aesthetics or cooling capabilities.
The dominators are sick danny. I used to own the 2GB set. Are going with 4 gigs? BTW, you'll have to OC to 1066 or above; they run out of the box at 800.
Yeah, I'll be getting 4GB. Though 2X 2GB sticks, instead of the 4X 1GB sticks I have now.
Really? That'd odd. Not really a problem though. Thanks, Mike!
Yeah, just check the speed they're running at in the BIOS. If they're at 800, raise the speed to 1066-ish and make sure the voltage is at 2.1. You gettin the fan too?
dominators easy!
pitty you aint got the dominator ram cooler, i removed the blue stickers off mine and they look really good black
its too bad, if many people had tried the reapers you'd all know :P
800mhz overclocks to 1200mhz @ 5-5-5-18
i never knew that! if the reapers come with the fan i guess they win for cooling, but the heatpipe works really well on the reapers :)
EDIT: meant to say if the dominators come with the fan :rolleyes:
Right. I manged to take my dominators above 1200 stable without raising the voltage above 2.3 (with the fan ;)). Heat isn't too much of an issue, tbh. As far as the reapers, at the most, a good intake fan on the side panel should suffice for heavy OC'ing. The heatpipes are work well, from what I've read.
is the fan that comes with the dominators loud? i need a bit more ram and cant seem to find my current set any more...
:eek: expensive-ass ram lol.
thank you for the link though, i did see one set for $40 that i will check out :)
haha. That's what happens when a product reaches EOL. You could search around other forums and see if you can find a set used. :)
