New build: i7 or Octocore? -Need info on Octo's, help please!
Jawn
Alright, the time has come.
I'm upgrading my tower and I want a good render monster for 3D and AfterEffects.
Here's the i7 920 build I had in mind:
https://secure.newegg.ca/WishList/MySavedWishDetail.aspx?ID=6816129
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131365
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119160
OCZ StealthXStream OCZ700SXS 700W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341019
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145224
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM SATA 3.0Gb/s 3.5"
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136296
Western Digital Caviar Green WD10EADS 1TB SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136317
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827136152CVF
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116488CVF
Hesitating between these 2 cards:
SAPPHIRE TOXIC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102815
HIS Hightech H487QT1GP Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported IceQ 4+ Turbo
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814161265
It's going to cost me about 2000$ before shipping.
I did a bit of research and an Octocore setup would cost me about 400-600$ more (lower end octocore, not 1366). I think that it's well worth it considering I have double the cores, but here's where I need help... I'm not to familiar with the i7's performance vs Octocore 771. Is it worth the trouble going the server board route to have Octo's?
Here are the Octocore components I had in mind
Intel Xeon E5410 Harpertown 2.33GHz 12MB L2 Cache LGA 771 80W Quad-Core Processor
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819117149
ASUS Z7S WS Dual LGA 771 Intel 5400 SSI CEB Dual Intel Xeon Server Motherboard
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131272
How does an Octocore stand up to the i7 920? Is it worth the extra money and hassle? Should I just invest in the i7 940?
Any suggestions and help is appreciated. Thanks!
personally, i would go the octocore route, especially with what you're doing, not sure if you can get it yet in canada or not, but they do have dual 1366 socket motherboards out there, and if you can afford it/find it, i would look into that, as you could have something like 24gb's of ram, crossfire, and 16 threads/8 cores
Are you making a server or what? You don't need a server class board to play games, and the extra cores won't do you much good for everyday use.
Your build is basically the same as the computer I'm using right now, and this thing is more than I need.
Skip the 940, it's not worth the extra money as the 920 will easily clock up to and over the stock 940. I run my 920 at 3.43Ghz with no issues.
As for the "Octo-Core", the i7's are Hyperthreaded, so each core runs two threads.
Looks an awesome build,I would got for a 260GTX over that 4870 but thats just me.
As for your Operating system,Just download and use X64 bit Windows 7...its good for a year and then if you like it you can but it when its released.
Answer:
If you can afford it.... Go dual i7's, but if not, for rendering i would say two core 2 quads/xeons is better than a single i7.
What do I need to add on the octocore board to match the P6T's functions?
I don't see any sound jacks on the octo board. So I'm guessing I need to add a sound card.
Thanks for your help.
The second board i listed(http://www.newegg.com/Product/Product.aspx?Item=N82E16813182192) has sound and a pci-e x16 slot, and is atx form factor and would fit into a standard full tower case;) Also, remember these are server boards and you need to use registered memory such as:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134944
Yeah that was my next question (the ram). I was thinking of going with the first board though and not the one with the integrated sound card.
Thanks a lot for your advice, it has been very useful to me. I appreciate the time you're taking to help me out.
