Do you have to burn in a new PC build?
Jamin43
banned
I remember reading years ago after a PC is built - that Dell did a burn in test - something like running it for 24 hours or a week before sending your equipment?
If you're building your own PC - is this step unnecessary ( just flip the switch on for normal use and thats' your burn in test ?? ). I haven't seen any mention of it in my PC building book - or in an online illustrated guide.
Thanks
just use it normally, and if something goes wrong, than well you know something is wrong with it :D
when it comes to overclocking, you should test for stability by stress testing for a minimum of 12 hours (better to do at least 24 though). maybe since some dells come factory overclocked, that is what the "burn in test" was referring to.
What they're talking about is a chemical change that occurs in the thermal compound between the CPU and heatsink. When you first fire up a computer that has new thermal compound on it, you can expect somewhat higher than average temperatures. Those temperatures will lower considerably over about 24 hours of use, and then continue lowering a bit more over about a week. This period during which the thermal compound changes and becomes more conductive to heat is often refered to as the "burn in" period.
Dell is somewhat infamous for using cheap parts. I've seen a lot of their desktops that don't even have a CPU fan, but a sort of funnel that runs from the rear case fan to the heatsink. It's likely that some of their computers had overheating issues for the first day or week, so they decided to hold onto them during the burn in period to reduce product returns.
Or unless you CF name is anything-PCI-related (...) and you swear by a 48-96 hour burn-in for your new PC, fuggedaboutit:)
If you build a new PC and it survives: A) the OS Install, B) the OS Update, C) the driver update, and D) the Misc. Software install, then you are good-to-go.
Any temps you monitor during those stages are random and will only drop a few degrees lower as the TC warms/cools and adapts to the hardware. It's like a new car engine - be nice for the first 500 miles and it will treat you lovely for years to come.
I personally believe in a burn in period before the return privileges expire for not only all parts of a new build, but any new parts added later on.
For a CPU and heatsink, Prime95.
DVD burner? Burn lots of DVDs and CDs, and verify the burnt contents, too.
Hard drives? Repeated virus scans and defragging.
Sound card? Continuous playback.
Video card or LCD display? Play DVD movies continually.
Power supply? Folding@Home.
And so on.
If any part I buy is going to fail, I want it to fail when I can return it and get a new one.
I had read somewhere that the "average" computer is run just 2 hours a day. So if I run parts for 72 hours straight, right there is 36 days' worth of use in three days. If a part can last through that, then it would last more than the maximum of a 30 day return period and will probably continue to run well for years. Any electronic equipment that I've done this on and it made it through 72 hours of solid use has lasted me for years.
I checked download.com for Prime95 - and it is listed as supported up to Windows XP. Have you tried it on Vista or Windows 7?
