New Build for a friend
Memory, faster timings and a good bit cheaper:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
As for the operating system... you might wana think about using windows 7 release candidate(free download from microsoft) since windows 7 will be released sometime by the end of the year.
Any reason to use G-Skill over OCZ gaming memory or vice versa ?
Brand G.SKILL
Model F3-12800CL8TU-6GBPI
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 6GB (3 x 2GB)
Speed DDR3 1600 (PC3 12800)
Cas Latency 8
Timing 8-8-8-21
Voltage 1.6V -1.65V
Multi-channel Kit Triple Channel Kit
Features Compatible with Intel Core i7 series CPU for Intel X58 Motherboard
Recommend Use High Performance or Gaming Memory
Manufacturer Warranty
Parts Lifetime limited
Labor Lifetime limited
OCZ said:
Model
Brand OCZ
Series Gold
Model OCZ3G1600LV6GK
Tech Spec
Cas Latency 8
Timing 8-8-8-24
Voltage 1.65V
Heat Spreader Yes
Features Gold Z3 XTC Heatspreader
Designed specifically for the Intel X58 chipset / Core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
Thanks
G.Skill memory is better than ocz, as ocz has had quite a bit of compatibility issues, Also, the G.Skill has better timings than the ocz. ALso, as far as the power supply... it may be somewhat overkill, but leaves plenty of room for future upgrades such as sli, newer cpu's, etc. Plus if its ~50% load then it has higher effeciency and will last longer than a psu at ~80% load. But an 850W corsair power supply would be nearly half the price, and only a 150W difference:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
Is Patriot Better than GSkill?
and which is the best brand in memory I always thought it was corsair but as it turns out no
There is absolutely no need to spend that much money on memory unless you plan on highly overclocking your memory, G.Skill memory is excellent for this budget range. If you are going to save on the psu, you would notice more of an improvement by going with a 30gb ocz ssd to install windows/games onto. If you are going to go with better memory though at this budget range, i would go for something like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226030
I've used G-skill for a DDR upgrade recently and loved it. The cust service is a bonus too - I like that they are actively answering customers in the New Egg reviews section.
I'll go with the G-Skill again then :good:
Thanks
Dont go with ocz ddr3, i would recommend straying away from it as there are alot of compatibility issues with it. Id still recommend this:
Still might wanna think about going with a 1.5TB drive, 50% more storage than two 500gb's and ~$10 less total.
