bomberboysk
Ok, heres something that i find debateable in these forums alot- should you have more case fans blowing out than in(negative pressure), or more blowing in than out(positive pressure).There have been alot of conflicting interests about this, and recently in an article in CPU(or maybe maximum pc, i forget which one) they author recommended positive pressure as it would push the heat out any open vents in a case, while other places ive read negative pressure is better(which is what i have always assumed to be better). And while balanced intake/exhause would more than likely be the best way, What do you guys think about this?(just a discussion btw)
