Good Build or Not
ASRock A780GMH/128M AM2+/AM3 AMD 780G HDMI Micro ATX AMD
ASUS EN9500GT TOP/DI/512M GeForce 9500 GT 512MB 128-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Rosewill Stallion Series RD600N-2SB-SL-BK 600W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply
AMD Athlon 64 X2 7750 Kuma 2.7GHz Socket AM2+ 95W Dual-Core black edition Processor Model AD775ZWCGHBOX
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-2GBPK
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
total is 338 what do you guys think?
Imo, spend a few extra on this gpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102822
PSU, rosewill is alright for cheap but this ocz is more effecient and would suit fine, plus ocz is a good quality psu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341012
Memory, 4gb>2gb:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820178219
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220335 (Great price after rebate)
Also.... what case you gonna be using?
OCZ is the best psu for the price....
I would recommend one more change, go with a full atx mobo such as this(go with the ati card though, as this mobo supports crossfire, and down the road you could just toss in another 4830 and almost double graphics performance):
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131381
which graphic card will run fifa at a good price under 100
Ati Radeon HD4830 or an HD4770 if you go with the crossfire compatible board i mentioned earlier in the thread, as they are ati(crossfire compatible) cards. The HD4770 is probably the best card in its price range also.
i want to go with nivdia and i think im going to stay with the current one i choose is the one i pick bad or something
