Which of The Two Should I Get?
...as more memory doesnt necessilarly make a computer faster unless you are utilizing all your memory to begin with, and you more than likely arent unless you edit HD video while having high megapixel images open in photoshop.
Ah, okay! So I guess 4GB -would- be enough. Thanks for the explanation and for all the help, dude. :)
Dont buy parts from bestbuy, newegg is the best place to buy anything electronic;)
i would add tigerdirect to the not-buy list also, their support is terrible
Tigerdirect is fine, ive purchased alot of things from both them and newegg and never had a problem(with service that is, ive had a few things come doa though from both).
