building noob and im stuck on this tower
NeoDude86
ok i am building a tower and it isn't working i turn it on and it appears to run but does not turn on the monitor i have an ecs mobo that does not have onboard graphics so i have a saphire ati board i have ram and a processor installed as well (my friend says the processor is fried but i take it out and the ram as well and it makes no noise while i get the typical beep when i have it in and i take out the ram so this says to me that it is working) but i do not have a harddrive hooked up yet and i'm wondering if this is why it won't load the bios through the graphics card otherwise everything appears to be ok i think i don't know can anyone help me out this is the first time i have built a tower without onboard graphics thank you
What kinda power supply you running? Try pulling one stick of memory out and see if it works then. You have the fan cable connected for the cpu fan?
it's a raidmax with 450 w max. i'll try that asap. and yes i have all cables hooked up nothing left unconnected (well except that i don't have a hard drive in it yet)
This may sound like a dumb question. But is your monitor plugged into the wall - and into your computer? Also - as a fellow newbie - I had to plug a separate PCIe power cable to my video card. May want to double check if that's the case with yours as well - if you didn't do so. Have you tested your video card in another PC - to see if that's the cause of your problems?
Best way to solve problems - is eliminate the things that you can rule out as the cause.
What are the rest of the specs on the machine? Raidmax psu's are notouriously unreliable, especially the ones that come with cases...
the psu works good i have it in my other tower which is why i can't just jump up and test it (and no it is not a psu that came with a tower i never use one that came with a tower i assume just buy another one) and yes i tested the card in my other tower and it detects it my biggest concern is this "what is the likelyhood of the processor being fried if the motherboard seems to work as long as it is in"
Could be mobo or cpu, just because it beeps doesnt mean its not the motherboard. Any chance you have another cpu thats compatible you could test? That would show if its mobo or cpu...
