bomberboysk
How do you know what kind of motherboard you need?
Depends on the cpu/budget your looking at. What kind of budget are you looking at and i could get you a rough list...
You pick a processor or CPU first. Depending on the Processor you choose - there are said motherboards that work with em. i.e. If you want a Phenom II - it's an AM3 Socket. They are compatable with AM3 socket Motherboards - and AM2+ of many manufacturers.
* If you chose an i7 platform - you have the 1366 x58 motherboards to choose from
* If you choose a dual core intel - you'll most likely have the 775 socket. You can get more compatability details at either the Intel's or AMD's website.
i.e.
AMD's recommended Motherboards per CPU
http://products.amd.com/en-us/RecommendedMBFilter.aspx
I chose a MOBO based on number of reviews - what was said in reviews on Newegg.com / Brand / price and features. ASUS & Gigabyte are pretty much mainstream - reliable motherboards as a starting point. I chose Gigabyte - b/c they were noted as better customer service - and for my first build there was a chance I may call upon that C/S. Ultimately - I didn't need to as everything went together smoothely out of the box.
Okay--well I am definately on a budget...I am looking at..
CPU: AMD Phenom II X2 550 Black Edition Callisto 3.1GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Processor $109
or
CPU: AMD Phenom II X3 720 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Black Processor
I need to spend $800 tops--not including monitor, keyboard or mouse.
Western Digital is the brand, and Caviar is the name of those HDD's. WD1001FALS is the product code. 1TB means it has 1 terra bytes of space, meaning 1,000,000,000,000 bytes of space. 7200RPM is how fast the disk inside the hard drive is spinning (RPM = revolution per minute). The faster the RPM, the faster it access information. 5000RPM is average. 16MB cache is basically the same thing I explained earlier about the CPU level 1, level 2, and level 3 cache. It temporarily holds information to speed up processing.Could someone explain what the specifications mean on an internal hard drive?
Example--What is the difference?
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives
Western Digital RE3 WD5002ABYS-01B1B0 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
iBuypower Gamer 528GN Gaming PC
AMD Phenom x4 9550 Quad-Core processor
Asus M2A-VM Mainboard
4GB High-Speed DDR2-800 Memory
20x DL DVD+/-RW Drive
16x DVD-Rom Drive
500GB SATA Hard Drive
Onboard Audio, LAN
ATI Radeon HD4850 512MB
NZXT Guardian 921 with ATI graphic + Blue Color Lighting
580 Watt PSU
12-in-1 media card reader/writer
Keyboard/Mouse
This poor guy has been bullied into building his own pc, even when he's stated several times that he doesn't have the time to do it, or the confidence.
Why couldn't someone just answer his question?
I actually looked at that case--I was just worried that less fans might be bad???
Thanks for the feedback!!
I got the Antec 300 as a budget case - and am very happy with the air flow. Comes with 2 fans ( manual 3 speed adjustable ) and has room to add 3 more - side vent / 2 front vents.
Not as " cool looking " as the one you posted - but great air flow. And it's solidly built.
http://www.newegg.com/Product/ShowI...ec Three Hundred Black Computer Case - Retail
If you're not in any hurry - you should be able to pick it up for free shipping at some point in the not too distant future.
YOutube is a good resource to see how the features of any given case actually work too.
http://www.youtube.com/watch?v=UX_nXwX_EzU
Yeah, the antec three hundred is a great budget case, but a killer when you cant get it for free shipping![]()
