EVGA GTS 250 or EVGA 9800GTX+ SCd
DSM1999
Hey guys which one is the best buy from these two....
EVGA 01G-P3-1156-TR GeForce GTS 250 Superclocked Edition 1GB 256-bit GDDR3 PCI Express 2.0 x16
or
EVGA 512-P3-N884-TR GeForce 9800 GTX+ Superclocked 512MB 256-bit DDR3 PCI Express 2.0 x16
Both are around the same price.
Depends on your gaming resolution.
GTS 250 and 9800GTX are pretty much the same card....if you have a small case then GTX 250 would be better.
Shame your PSU isn't a 650/700w GTX 260 out performs both and is similar in price.
Whatever is cheaper, pretty much the same card...
Thanks
I'm using 1920x1200
I have a Cooler Master mid case.
Since they are both the same Ill will go for the 1GB one just for the heck of it.
I have a 600w psu. Just remember that the psu is not based exactly on the watts, it is mostly based on the amount of amps.
I will look into the 260 and see how much it is.
Thanks
Also, if you go for a PNY model, $50 off any of the cards listed here with the coupon code if someone hasnt already used it:
http://www.computerforum.com/152902-coupon-code-newegg.html
Sorry but dont like PNY. Im a EVGA and XFX guy. Thanks anyways.
Guys
What about from GTS250 to GTS260? any big difference? is it worth the 40bucks difference?
Also, lookin at my specs at the bottom, whats the best graphic card I can buy?
