Which monitor is better?
Jack Sparrow
I am looking for a cheap monitor but big enough to watch movies and what not. This vistron 37" HD is 1080i but it also says it is progressive scan. And on the comments people reccon they have used their ps3s/xboxs as 1080p. Does this matter at all. And is the price right? I am a novice at buying monitors any help appreciated!
http://www.ebuyer.com/product/140426
Vistron 37" HD Ready LCD TV built in Freeview 1366x768 1200:1 500cd/m2 1xHDMI/VGA Gloss Black 1 Year Warranty
Television Picture Features
* 1080i High Definition Ready.
* Integrated digital (freview).
* 37" widescreen TV
* Resolution 1366 x 768 pixels.
* Brightness 500 cd/m2.
* Contrast 12001.
* Viewing angle 170/170degrees.
* Progressive scan.
Connectivity
* 1 x HDMI sockets.
* 1 x SCART sockets.
* PC input socket.
* Component video socket.
* Composite.
* Headphone socket.
* AV socket.
Sound Features
* Nicam stereo sound.
* 2 x 8w RMS power output.
Freeview Features
* Digitally interactive.
* Digital text.
* Digital Video Broadcasting (DVB) subtitles available.
* Auto setup.
* Auto scan for new channels.
* Now and next electronic programme guide (EPG).
* 7 day electronic programme guide (EPG).
* Top Up TV compatible.
Additional Features
* Teletext.
* Fastext.
* UHF and VHF tuner.
* Auto setup.
* Auto search tuner.
* Auto search sorting.
* Auto search labelling.
* Sleep timer.
* Child lock.
* NTSC compatible.
* Remote control requires 2 x AAA batteries.
* 230v AC mains operation.
* Stand by Power consumption: <2w
* Complete with tabletop stand.
Dimensions
* Size of TV (H)66, (W)95, (D)13cm.
* Size of TV with stand (H)69.5, (W)95, (D)32cm.
* Weight of TV with stand 25kg
* Vesa: 440mmx220mm
Or
http://www.ebuyer.com/product/160823
Samsung LE32B450 Series 4 32" HD Ready LCD TV Freeview 1366x768 HDMIx3/PC/Scart W/Mountable Gloss Black 1 Year Warranty
3 HDMI
Three High Definition Multimedia InterfaceTM (HDMI) connections make your TV a multimedia centrepiece. Connect HD digital devices like disc players, game consoles, and satellite dish components into the 2 rear connections and use the side-mounted input for cameras, camcorders, and laptops. HDMI is the best performing interface for displaying an HD source on an HDTV.
down firing speakers
Better design and deeper sound creation. With SAMSUNG’s Down-Firing Speakers, now you can fill your room with deeper and clearer sound levels.
DNIe+
SAMSUNG’s proprietary picture quality enhancing engine.
DNIe+ Engine technology performs to optimise overall picture qualities.
wide colour enhancer 2
More natural and deeper colour SAMSUNG’s Wide Colour Enhancer extended to display the natural greens and blues. Additionally, Wide Colour Enhancer 2 technology is upgraded to reproduce the natural red colours.
Specifications
VIDEO
* Screen Size 32"
* Dynamic Contrast Ratio High Contrast
* Movie Plus No (50Hz)
AUDIO
* Sound Effect System SRS Trusurround HD & Dolby Digital Plus
* Sound Output(RMS) 10 watts x 2
* Speaker Down Firing
Input & Output(Side)
* HDMI 1
* composite (AV) 1
* Headphone No
Input & Output(Back)
* HDMI 2
* composite (AV) No
* PC input (D-sub) 1
* Component(Y/Pb/Pr) 1
* RF Input 1
* Headphone No
* RS232C (for Service only) No
* Scart 1
* Cabinet
* Color Black
* Swivel (left/right) Yes
Feature
* Picture-in-Picture No
* Sleep Timer Yes
* Clock & On/Off timer Yes
* Auto Channel Search Yes
* Auto Power Off Yes
* Auto Volume Leveller Yes
* Anynet+ (HDMI-CEC) No
* Teletext(TTXT) 1000p
* OSD Language Europe 25 Language
* Game mode Yes
Dimension
* Set size(WXHXD) with stand 797.7 x 576.5 x 252mm
* Set size(WXHXD) without stand 797.7 x 530.5 x 84.8mm
* Package size(WXHXD) 890 x 599 x 173mm
Weight
* Set weight with stand 11.4kg
* Set weight without stand 9.1kg
* Package weight 14.9kg
Accessory
* Wall Mountable Yes (32 - 40": 200 x 200)
* Remote Controller TM940
* Batteries, AAA type Yes
* ANT- Cable No
* Power Cable Yes
Power
* Power Supply AC220-240V 50 / 60Hz
* Stand-By Power Consumption < 0.3 watts
the samsung is going to be the better tv in terms of picture but i dont think that samsung has pc input if you were intending to use it with pc. i know the 5 series version of that tv does have the pc input though and it also gives a very good picture i would know because i have one:D i would advise you to have a look at the 5 series.
samsung 5 series is abit out of my price range:( lol
You must be rich!
How do you think the Vistron would do as a monitor?
