UpskirtHayley
done with this thread.
ok now that i see opinions.. this thread is done.
Is this supposed to be a joke?
I think the i7 system because you have a better video card in it which will allow you to run Crysis at very high settings.
I'm starting to think so too.![]()
1: intel i7 950 / 1.2gig ram / GTX 285
do you not mean 12 GB ram? it would be pointless running that rig with only 1.2GB ram
the first system. the GTX285 is way more powerful than the 8800
That it exactly how they would perform. If you knew the answer why did you ask?
I don't think it would be too playable on either rigs as while I can play Crysis on my rig (X2 5000+, 2GB DDR2, and 9600GT) it doesn't work very well on max settings so I doubt a 4400+ with 16GB RAM and an 8800GTS would be much better.
x2 5000+, 2gb, 9600gt is your current rig..... buy 4x 4gb and throw your 2x 1gb on ebay. guarenteed youll play fine. although you might get 17fps.
Lol, a 9600gt wont play crysis on high no matter how much ram...
She was half right... I could play it on max and get 17 FPS, but that's hardly what I'd call playable.
But if a 9600GT can't play Crysis on max I doubt an 8800GTS would do much better.
I'd take my brother's 12GB DDR3 RAM, slap it in the i7 rig and PLAY CRYSIS!
Or is that not an option?
