Is it possible to just install Windows on your Mac?
hkgant
Is it possible to partition your Mac so that you can only boot into Windows and is it possible then to completely wipe Windows and just use the Mac OS afterwards? I know you can set your Mac to automatically boot into Windows but I don't know if you can do the above. Thanks.
Oh really? So you can partition it so that you ONLY dedicate your hard disk to Windows through Boot Camp? I didn't know that. Thanks. I knew that you could make your computer start up automatically to Windows but I didn't know you could partition your disk that way. Are you sure?
Yes, just read through the instructions;)
