New Rig Needs some opinions!!!
makes sence thanks for clearing that up lol got excited when i saw the 4x though ...=[ was that the only motherboard with watercooling barbs on it? or was that one the best out of the bunch?
All you need is 6gb really atm,just grab another 6gb in a year or so when the price drops;)
ok thanks.... You really seem to like building computers.... every time I see someone asking about what parts to get or whatever you just go and give them a whole computer with links to see the item and everything... It's cool that you take the time to do that..:good:
Have time and nothing better to do, so why not:P
As far as i know, in this feature range that would be the only board that has watercooling barbs/waterblock already on it. Although if you dont care about watercooling that as well, another great mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130215
I was looking on gigabytes website and that really is a good motherboard.... doesn't say if the PCIe work at 16x 16x 8x or 16x 8x 8x or all 8x
also what do you think if i got a ssd drive? Heard they are faster than regular hard drives...
Could drop one of the western digital 1TB drives and go for one of these as a boot drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820141419
But imo, just like the extra 6gb of memory, wait it out a year or so, then upgrade to an ssd. Those caviar blacks are fast as you really need at the moment. In a years time you will be able to get a faster drive with probably twice the capacity for the same price.
If it's not necessary I won't get it just a thought though... i'm excited just thinking about it when all the parts are here and i get it up and running...=]
Yeah, new builds are always like that. Dont forget to grab a tube of thermal paste though also, Tuniq TX-2, Arctic Cooling MX-2 and OCZ freeze are pretty much the best, just grab whichever has free shipping on newegg at the moment(cuz they will charge $6 shipping on a $5 tube of thermal paste)
=3,700th Post=
i'll have to find a guide on how to install the thermal paste properly.. I had my friend do it on my current computer because since it was my first time i didn't want to screw up lol.... I don't want anyone's help this time just me ( hopefully i don't screw up though)
If you go with the watercooling kit, id suggest having a friend help you hook it up if you havent done it before. Best route for that imo(for future use) would be Pump->CPU Block->Mobo block->Radiator->reservoir->pump again. Thermal paste isnt hard to put on, just put a small drop on the middle of the cpu(about the size of a grain of rice) and put the heatsink on, it will spread itself.
i'll be suer to recheck 2-3 times to make sure it doesn't leak all over the place..
Yeah, a good trick to getting them on the barbs is heating the ends in hot water to expand them a little bit before putting them on. Another thing though, instead of using the included hydrx additive, just add in a piece of silver as biocide and run pure distilled water(will have better temps than without an additive, and water doesnt break down over time like additives do):
http://www.petrastechshop.com/sikibyia.html
total comes out to alittle over 4k.... I though it might jump to 5 after the hdtv but newegg never keeps from amazing me with thier prices....
