possible to get OS from partition on hdd?
dylan123
Hey guys, about 8months ago i decided to buy this pc without thinking to much about it and anyway im needing to upgrade it to do what i want it to do. My question is, is it possible to get my o/s off the petition on my hdd onto a DVD(or something else) so i can use it when i get my new parts?
I don't believe so. When you buy a factory pc the OS is OEM and usually cannot be extracted, although I could be wrong but I'm pretty sure I'm right.
OK well thats not want i wanted to hear but onto plan number 2. Do you think if i was to use my friends vista discs which is the same version and used my product key it would work?
Yeah that would work fine. Doesn't matter what edition of vista either as long as you have a good key. Are you talking about the vista restore partition being on a seperate drive like what HP does? There is a way to do it, but you may have to contact your computer company on a how to though as I am not totally sure. But if you do use your friends vista cd, just make very sure you have all of your correct drivers on a seperate media before you do so you won't have as much of a problem. Otherwise yeah it should work just fine with your key and his/her cd.
that isn't true at all.
You can use the key that you have on your other system but you must use the copy of vista that it is good for, if you have home premium, install home premium and use the key, if you have ultimate, install ultimate and use the key, if you have on your system now home premium you can't then go and install ultimate and use the home premium key.
1. I don't think it will work anyway
2. It is illegal, you don't have the legal rights to use a copy Vista you have not bought, only the one you have. You have bought a contract for the version of Vista you have and no other
When you end up doing the switchover make sure that you have all of the drivers you need, you can have them on a memory stick, disc whatever, just make sure you have them. Even if you only get your internet adapter drivers (if there is wireless card, generally ethernet ports in desktops auto install), then you will be able to get to the internet and download the others, but if you get onto the internet then vista will update your graphics card drivers itself so that shouldn't be a problem, but even so i wouldn't trust vista to do it, get the lattest version yourself.
you can do it but occasionally it will say it is in use. In that situation contact Microsoft and bullshit em, say your hard drive went, you upgraded it and now the key won't work. They will disable your old key so it will never be accepted by any microsoft authentication and if you use it then connect your system to the internet your OS will say it isn't valid and carry on the 30 days to input a proper one.
Once they have disabled your old key they give you a new one which works fine and dandy :)
