Nebook---How about this one? COMMENTS?
luckyboomstick
I am considering a netbook--this is what is important to me: upgradeable ram 10inch screen, atom processor and something n270 or n280, long battery life, wifi b/g.... so this is the one i was thinking--
I am going to use for surfing, listening to music, youtube video, traveling, something ultraportable i can use around house----- I already have a traditiional laptop, and monster desktop-----
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220504
or perhaps
http://www.newegg.com/Product/Product.aspx?Item=N82E16834220534
any suggestions?:):confused:
Id go for the first one of those two, but to be honest you might wanna think about waiting until some ion based netbooks come out, have a dual core atom and 9400M gs integrated graphics;)
when does the dual atom come out? what is the ion based book? do you have links? what about prices? really i am 3 minutes from purchasing----- have it in the cart on the egg------------------------ the 1000he is upgradeable correct? in terms of ram--- was thinking of the crucial ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148162
suggestions?
Yeah it has upgradeable ram. I would go with this memory as its better CAS, and 533mhz is the fastest memory will go in netbooks anyhow:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104100
Ion based netbooks wont be out for at least a month or two, so if you want it now then that asus is prolly the best one of the bunch;)
Darn. Just after I bought my netbook... how come I never heard about Ion before now. Have I been sleeping under a rock or something?
Ah well, it'll probably cost more than a wind anyway... I just hope it doesn't cost the same amount right when it comes out. :P
EDIT. I sure had heard about it... somehow I had completely forgotten about it, or just not thought about it going into netbooks. :rolleyes:
actually irishwhistle---- bomberboysk----- was telling you about it, i read your forum before creating this on. do you like your msi? does it also do the inteligent scrolling on the pad like the iphone uses------ the asus i am considering seems to operate that way.
or perhaps
I say get the 1000HE. Have you seen the blue version?
