Problem!!!!!!!
yuki953
Ok, something new that ive never seen befor...
My computer runs fine.. Its good, fast (for its specs) and is perfect for me..
Problem: Whenever i try to open something, like a game or internet, even minesweeper on the days that im bored... it takes like 4 minutes to pop up... when its finaly up it runs fine though... so its not a hard ware problem...
its never done this befor... and it just started... whats rong?
Windows vista basic sp1
Sounds to be a hard drive problem of some sort. Download and run seatools for windows, run a long generic and smart self test, see if it fails either of them.
could be running low on memory from too many open programs and the page file is off or set really small. Virus maybe? check the open applications for anything suspicious.
allready have... first thought was it could be a virus...
if it was memory then the programs would run non smooth... but they do once there open
It would :rolleyes: ;)...Spyware can cause all sorts of problems,Worth giving it a scan.
wow cant beleive how simple that was... ran the combofix, and only the combo fix...
heres log:
Code:
ComboFix 09-06-22.08 - Shaka 06/23/2009  3:02.1 - NTFSx86
Microsoft® Windows Vista™ Home Basic   6.0.6001.1.1252.1.1033.18.1790.1266 [GMT -7:00]
Running from: c:\users\Shaka\Downloads\ComboFix.exe
SP: Windows Defender *enabled* (Updated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
(((((((((((((((((((((((((((((((((((((((   Other Deletions   )))))))))))))))))))))))))))))))))))))))))))))))))
c:\$recycle.bin\S-1-5-21-2281177520-812670149-4258392394-500
c:\$recycle.bin\S-1-5-21-2330998901-1206937444-1990037922-500
c:\$recycle.bin\S-1-5-21-957388825-4026625574-79556735-1000
c:\windows\system32\11BA.tmp
c:\windows\system32\1908.tmp
c:\windows\system32\1ABD.tmp
c:\windows\system32\5ED2.tmp
c:\windows\system32\6213.tmp
c:\windows\system32\702D.tmp
c:\windows\system32\A4B7.tmp
c:\windows\system32\EADA.tmp
c:\windows\system32\SystemService32
c:\windows\system32\WBkbSv6.vbs
c:\$recycle.bin\S-1-5-21-2281177520-812670149-4258392394-500\desktop.ini
c:\$recycle.bin\S-1-5-21-2330998901-1206937444-1990037922-500\desktop.ini
c:\$recycle.bin\S-1-5-21-957388825-4026625574-79556735-1000\desktop.ini
c:\users\Shaka\AppData\Roaming\02000000a063657d608C.manifest
c:\users\Shaka\AppData\Roaming\02000000a063657d608O.manifest
c:\users\Shaka\AppData\Roaming\02000000a063657d608P.manifest
c:\users\Shaka\AppData\Roaming\02000000a063657d608S.manifest
c:\windows\system32\dsprop32.dll
c:\windows\system32\GroupPolicy000.dat
c:\windows\system32\SystemService32\BF6B.tmp
(((((((((((((((((((((((((   Files Created from 2009-05-23 to 2009-06-23  )))))))))))))))))))))))))))))))
2009-06-23 08:45 . 2009-06-23 08:45	--------	d-sh--w-	c:\windows\system32\SystemX86
2009-06-19 10:04 . 2009-06-19 10:04	--------	d-----w-	c:\programdata\3DVIA
2009-06-19 10:03 . 2006-09-28 23:05	2414360	----a-w-	c:\windows\system32\d3dx9_31.dll
2009-06-19 10:03 . 2009-06-19 10:03	--------	d-----w-	c:\program files\Virtools
2009-06-19 07:58 . 2009-06-19 07:58	--------	d-----w-	c:\windows\system32\Adobe
2009-06-17 06:41 . 2009-06-17 06:41	--------	d-----w-	c:\program files\Webzen
2009-06-15 22:36 . 2009-06-15 22:36	--------	d-----w-	C:\zee_store
2009-06-15 22:19 . 2009-06-15 22:19	--------	d-----w-	c:\program files\HyCam2
2009-06-13 06:21 . 2009-06-13 06:22	--------	d-----w-	c:\users\Shaka\AppData\Local\Microsoft Games
2009-06-10 06:40 . 2009-06-10 06:40	--------	d-----w-	c:\program files\NickOnline
2009-06-10 06:39 . 2009-06-10 06:39	--------	d-----w-	c:\users\Shaka\AppData\Local\Downloaded Installations
2009-06-09 22:59 . 2009-06-09 23:16	--------	d-----w-	c:\users\Shaka\AppData\Roaming\TeamViewer
2009-06-03 02:37 . 2009-06-03 02:38	--------	d-----w-	c:\program files\FileZilla FTP Client
2009-06-02 04:33 . 2009-06-02 04:33	--------	d-----w-	c:\program files\Sun
2009-05-31 03:52 . 2009-06-17 06:45	34	----a-w-	c:\users\Shaka\jagex_runescape_preferences.dat
2009-05-31 03:51 . 2009-06-03 14:26	--------	d-----w-	c:\windows\.jagex_cache_32
2009-05-30 21:22 . 2009-06-02 04:33	410984	----a-w-	c:\windows\system32\deploytk.dll
2009-05-30 01:06 . 2009-05-30 01:06	--------	d-----w-	c:\users\Shaka\AppData\Roaming\Template
2009-05-29 01:51 . 2009-05-29 01:52	--------	d-----w-	C:\ijji
2009-05-28 06:17 . 2009-05-28 06:17	--------	d-----w-	c:\users\Shaka\AppData\Roaming\NCH Swift Sound
2009-05-28 06:16 . 2009-06-05 04:29	--------	d-----w-	c:\programdata\NCH Swift Sound
2009-05-28 06:16 . 2009-05-28 06:17	--------	d-----w-	c:\program files\NCH Swift Sound
2009-05-27 00:02 . 2009-05-27 00:02	--------	d-----w-	c:\users\Shaka\New Folder
2009-05-26 23:31 . 2009-05-26 23:32	--------	d-----w-	c:\programdata\RapidSolution
2009-05-26 23:30 . 2009-05-26 23:30	--------	d-----w-	c:\users\Shaka\AppData\Local\Scramby Recordings
2009-05-26 23:30 . 2009-05-26 23:30	--------	d-----w-	c:\program files\RapidSolution
2009-05-25 19:53 . 2009-05-25 20:07	--------	d-----w-	c:\users\Shaka\AppData\Roaming\Ventrilo
2009-05-25 19:52 . 2009-05-25 19:54	--------	d-----w-	c:\users\Shaka\riotscape.comv4
2009-05-25 19:48 . 2009-05-25 19:48	--------	d-----w-	C:\.Cozmoscape_cache
2009-05-25 19:37 . 2009-05-25 19:37	--------	d-----w-	c:\program files\Ventrilo
2009-05-25 19:36 . 2009-05-25 19:36	--------	d-----w-	c:\program files\Common Files\Wise Installation Wizard
((((((((((((((((((((((((((((((((((((((((   Find3M Report   ))))))))))))))))))))))))))))))))))))))))))))))))))))
2009-06-23 08:45 . 2009-06-23 08:45	0	----a-w-	c:\windows\system32\1C53.tmp
2009-06-23 08:45 . 2009-06-23 08:45	0	----a-w-	c:\windows\system32\1A11.tmp
2009-06-21 23:14 . 2009-06-21 23:14	0	----a-w-	c:\windows\system32\A8E5.tmp
2009-06-21 23:14 . 2009-06-21 23:14	0	----a-w-	c:\windows\system32\A6B2.tmp
2009-06-20 07:14 . 2009-06-20 07:14	0	----a-w-	c:\windows\system32\5F44.tmp
2009-06-18 15:14 . 2009-06-18 15:14	0	----a-w-	c:\windows\system32\187B.tmp
2009-06-17 06:43 . 2008-10-28 21:00	--------	d--h--w-	c:\program files\InstallShield Installation Information
2009-06-17 01:24 . 2009-06-03 05:14	--------	d-----w-	c:\users\Shaka\AppData\Roaming\FrostWire
2009-06-15 20:58 . 2009-06-15 20:58	0	----a-w-	c:\windows\system32\E8B7.tmp
2009-06-14 04:58 . 2009-06-14 04:58	0	----a-w-	c:\windows\system32\A265.tmp
2009-06-12 12:58 . 2009-06-12 12:58	0	----a-w-	c:\windows\system32\5C42.tmp
2009-06-10 20:58 . 2009-06-10 20:58	0	----a-w-	c:\windows\system32\16B6.tmp
2009-06-09 22:59 . 2009-06-03 02:48	--------	d-----w-	c:\users\Shaka\AppData\Roaming\FileZilla
2009-06-09 07:59 . 2009-06-09 07:59	0	----a-w-	c:\windows\system32\580A.tmp
2009-06-09 07:59 . 2009-06-09 07:59	0	----a-w-	c:\windows\system32\55D7.tmp
2009-06-07 15:59 . 2009-06-07 15:59	0	----a-w-	c:\windows\system32\FA7.tmp
2009-06-06 21:53 . 2009-06-06 21:48	--------	d-----w-	c:\users\Shaka\AppData\Roaming\gtk-2.0
2009-06-06 02:23 . 2009-06-06 02:23	--------	d-----w-	c:\program files\GIMP-2.0
2009-06-03 05:27 . 2009-06-03 05:27	0	----a-w-	c:\users\Shaka\AppData\Roaming\FrostWire\.NetworkShare\Incomplete\T-4506256-LimeWireWin4.16.6.exe
2009-06-03 05:14 . 2009-06-03 05:12	--------	d-----w-	c:\program files\FrostWire
2009-06-03 05:12 . 2009-06-03 05:12	--------	d-----w-	c:\program files\AskBarDis
2009-06-02 04:34 . 2009-05-11 00:24	--------	d-----w-	c:\program files\Flock
2009-06-02 04:33 . 2008-10-28 21:49	--------	d-----w-	c:\program files\Java
2009-05-30 01:06 . 2009-05-30 01:06	0	----a-w-	c:\users\Shaka\AppData\Roaming\wklnhst.dat
2009-05-22 01:38 . 2009-05-22 01:38	--------	d-----w-	c:\programdata\CCP
2009-05-20 22:33 . 2009-05-20 22:33	93	----a-w-	c:\users\Shaka\AppData\Local\fusioncache.dat
2009-05-20 04:55 . 2009-05-20 04:55	--------	d-----w-	c:\programdata\Turbine
2009-05-19 04:10 . 2009-05-17 07:41	--------	d-----w-	c:\program files\Axife Mouse Recorder DEMO
2009-05-19 01:24 . 2009-05-11 00:06	--------	d-----w-	c:\programdata\PMB Files
2009-05-19 01:24 . 2008-10-28 21:50	--------	d-----w-	c:\program files\BigFix
2009-05-19 01:21 . 2009-05-19 01:21	--------	d-----w-	c:\program files\Microsoft
2009-05-19 01:21 . 2009-05-14 23:23	--------	d-----w-	c:\program files\Windows Live
2009-05-19 01:21 . 2009-05-19 01:21	--------	d-----w-	c:\program files\Windows Live SkyDrive
2009-05-19 01:20 . 2008-10-28 21:39	--------	d-----w-	c:\programdata\Symantec
2009-05-19 00:11 . 2009-05-11 01:00	--------	d-----w-	c:\users\Shaka\AppData\Roaming\DNA
2009-05-19 00:06 . 2009-05-11 01:14	31871	----a-w-	c:\programdata\nvModes.dat
2009-05-18 02:19 . 2009-05-18 01:56	--------	d-----w-	c:\program files\TG Games
2009-05-17 10:12 . 2009-05-17 01:29	--------	d-----w-	c:\program files\Common Files\Blizzard Entertainment
2009-05-17 07:32 . 2009-05-17 07:32	--------	d-----w-	c:\program files\JitBit
2009-05-17 01:29 . 2009-05-17 01:29	--------	d-----w-	c:\programdata\Blizzard
2009-05-16 20:08 . 2009-05-16 20:04	--------	d-----w-	c:\programdata\NexonUS
2009-05-14 23:15 . 2009-05-14 23:15	--------	d-----w-	c:\program files\Common Files\Windows Live
2009-05-13 04:13 . 2009-05-13 04:13	--------	d-----w-	c:\users\Shaka\AppData\Roaming\InstallShield
2009-05-13 00:36 . 2009-05-13 00:36	--------	d-----w-	c:\program files\Common Files\INCA Shared
2009-05-12 22:13 . 2009-05-12 07:15	--------	d-----w-	c:\program files\Cheat Engine
2009-05-11 01:15 . 2008-10-28 20:57	--------	d-----w-	c:\programdata\NVIDIA
2009-05-11 01:14 . 2008-10-28 21:39	--------	d-----w-	c:\program files\Common Files\Symantec Shared
2009-05-11 01:14 . 2007-10-10 07:20	--------	d-----w-	c:\program files\Google
2009-05-11 00:24 . 2009-05-11 00:24	0	----a-w-	c:\windows\nsreg.dat
2009-05-11 00:24 . 2009-05-11 00:24	--------	d-----w-	c:\users\Shaka\AppData\Roaming\Flock
2009-05-11 00:15 . 2009-05-11 00:15	--------	d-----w-	c:\program files\SystemRequirementsLab
2009-05-11 00:05 . 2009-05-11 00:05	--------	d-----w-	c:\program files\Pando Networks
2009-05-10 22:45 . 2009-05-10 22:45	75264	----a-w-	c:\users\Shaka\AppData\Local\GDIPFONTCACHEV1.DAT
2009-05-10 22:45 . 2009-05-10 22:45	--------	d-----w-	c:\users\Shaka\AppData\Roaming\Symantec
2009-05-10 22:43 . 2009-05-10 22:43	--------	d-----w-	c:\program files\WalMart
2009-05-10 22:43 . 2009-05-10 22:43	--------	d-----w-	c:\program files\eBay
2009-04-27 07:42 . 2008-10-28 20:52	457248	----a-w-	c:\windows\system32\NVUNINST.EXE
(((((((((((((((((((((((((((((((((((((   Reg Loading Points   ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{201f27d4-3704-41d6-89c1-aa35e39143ed}]
2008-09-09 05:08	279944	----a-w-	c:\program files\AskBarDis\bar\bin\askBar.dll
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-02-07 3885408]
"WindowsWelcomeCenter"="oobefldr.dll" - c:\windows\System32\oobefldr.dll [2008-01-21 2153472]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-12 39792]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2008-05-02 13535776]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2008-05-02 92704]
"UpdateP2GoShortCut"="c:\program files\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" [2008-06-14 210216]
"RemoteControl"="c:\program files\CyberLink\PowerDVD\PDVDServ.exe" [2007-03-15 71216]
"LanguageShortcut"="c:\program files\CyberLink\PowerDVD\Language\Language.exe" [2007-01-09 52256]
"UpdatePSTShortCut"="c:\program files\CyberLink\DVD Suite\MUITransfer\MUIStartMenu.exe" [2008-09-25 210216]
"Turbine Download Manager Tray Icon"="d:\games\MMORPGS\Turbine Download Manager\TurbineDownloadManagerIcon.exe" [2009-06-17 472568]
"Axon"="c:\program files\NCH Swift Sound\Axon\axon.exe" [2009-05-28 835588]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-06-02 148888]
"RtHDVCpl"="RtHDVCpl.exe" - c:\windows\RtHDVCpl.exe [2008-05-20 6144000]
c:\users\Shaka\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
OneNote 2007 Screen Clipper and Launcher.lnk - c:\program files\Microsoft Office\Office12\ONENOTEM.EXE [2007-8-24 101784]
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
"EnableUIADesktopToggle"= 0 (0x0)
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\WinDefend]
@="Service"
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\FirewallRules]
"{DEE35472-02DF-4BF3-82A3-8FCCE03A76A0}"= UDP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{6235183E-A529-4480-A6BF-5BAFAD8A4229}"= TCP:c:\program files\Microsoft Office\Office12\ONENOTE.EXE:Microsoft Office OneNote
"{4FF9A41D-44E4-472B-8F10-E8CEC3915A2B}"= c:\program files\CyberLink\PowerDVD\PowerDVD.EXE:CyberLink PowerDVD
"{8F33D57B-DF6E-4745-AAB4-84B1CE92135B}"= UDP:c:\program files\Pando Networks\Media Booster\PMB.exe:Pando Media Booster
"{D5541458-A158-4523-B372-359C6E61E37C}"= TCP:c:\program files\Pando Networks\Media Booster\PMB.exe:Pando Media Booster
"TCP Query User{BDD5ECA9-ED17-4760-A8D4-8DA37A4464AE}e:\\website\\darkeden eternity\\darkeden.exe"= UDP:e:\website\darkeden eternity\darkeden.exe:DarkEdenEternity
"UDP Query User{423DFA92-EFDC-4E82-87B5-9AC3A91BF408}e:\\website\\darkeden eternity\\darkeden.exe"= TCP:e:\website\darkeden eternity\darkeden.exe:DarkEdenEternity
"{3FCD7F39-2E3F-4B6F-9D2F-DE10BDC9D22E}"= UDP:d:\games\MMORPGS\Turbine Download Manager\TurbineMessageService.exe:TurbineMessageService
"{61E2F275-B51D-424D-8854-D36029036A38}"= TCP:d:\games\MMORPGS\Turbine Download Manager\TurbineMessageService.exe:TurbineMessageService
"{6A811860-8771-4525-87EB-05812B0B78A0}"= UDP:d:\games\MMORPGS\Turbine Download Manager\TurbineNetworkService.exe:TurbineNetworkService
"{33461229-2F78-4C6F-AD5F-D3E5D77520B1}"= TCP:d:\games\MMORPGS\Turbine Download Manager\TurbineNetworkService.exe:TurbineNetworkService
"TCP Query User{68ED711B-63E0-4362-A1F7-2A1A7ACB3626}d:\\games\\mmorpgs\\lotro\\lotroclient.exe"= UDP:d:\games\mmorpgs\lotro\lotroclient.exe:lotroclient
"UDP Query User{F1E44B0E-F39B-4331-8F9C-E9404FC35329}d:\\games\\mmorpgs\\lotro\\lotroclient.exe"= TCP:d:\games\mmorpgs\lotro\lotroclient.exe:lotroclient
"{DD2AE297-DCAD-4844-8241-069C7D333A50}"= UDP:c:\users\Public\Documents\Blizzard Entertainment\World of Warcraft\WoW-3.1.1.9835-to-3.1.2.9901-enGB-downloader.exe:Blizzard Downloader
"{D133C274-5009-4302-BA9A-D143A0848816}"= TCP:c:\users\Public\Documents\Blizzard Entertainment\World of Warcraft\WoW-3.1.1.9835-to-3.1.2.9901-enGB-downloader.exe:Blizzard Downloader
"{FA45DC7A-2E71-44A5-AD8D-753B5AB1D701}"= UDP:3724:Blizzard Downloader: 3724
"TCP Query User{59D6D3E6-631E-4E4F-9AA0-9F7F40880324}d:\\games\\mmorpgs\\world of warcraft trial\\world of warcraft\\launcher.exe"= UDP:d:\games\mmorpgs\world of warcraft trial\world of warcraft\launcher.exe:Blizzard Launcher
"UDP Query User{24A3CF1B-6804-4A3C-A583-C6922D4F6F2F}d:\\games\\mmorpgs\\world of warcraft trial\\world of warcraft\\launcher.exe"= TCP:d:\games\mmorpgs\world of warcraft trial\world of warcraft\launcher.exe:Blizzard Launcher
"TCP Query User{0A84F347-5FEC-43C0-A0A3-E9BCE0222DAD}d:\\games\\mmorpgs\\eve onlnie\\bin\\exefile.exe"= UDP:d:\games\mmorpgs\eve onlnie\bin\exefile.exe:CCP ExeFile
"UDP Query User{A7FCB157-2B4B-4064-8F99-80D53D07F0DF}d:\\games\\mmorpgs\\eve onlnie\\bin\\exefile.exe"= TCP:d:\games\mmorpgs\eve onlnie\bin\exefile.exe:CCP ExeFile
"{6AA81266-8084-46B3-ADA8-4720078E79DF}"= UDP:c:\program files\Ventrilo\Ventrilo.exe:Ventrilo.exe
"{700046DB-4682-4F74-8B59-324110DB7B31}"= TCP:c:\program files\Ventrilo\Ventrilo.exe:Ventrilo.exe
"{0BADB332-5F1E-44C0-9D20-DB9A44135DAF}"= TCP:4100:uPNP Router Control Port
"{F8F9AB4B-271D-4416-8716-477B03C14AD4}"= UDP:81:Axon Virtual PBX Web Server
"{B2162C91-3190-4B2E-B292-CACC9CDFF213}"= UDP:c:\program files\FrostWire\FrostWire.exe:FrostWire
"{6FB3A106-C49D-4814-B246-08CA09CB04B2}"= TCP:c:\program files\FrostWire\FrostWire.exe:FrostWire
"{59BC1DC4-CE57-4477-A36A-3FB549AA95DC}"= UDP:d:\games\MMORPGS\Turbine Download Manager\TurbineMessageService.exe:TurbineMessageService
"{7967D570-DE89-4646-9105-C74B5E1717F1}"= TCP:d:\games\MMORPGS\Turbine Download Manager\TurbineMessageService.exe:TurbineMessageService
"{E7182381-6A1B-4551-808E-E76A5C20F74A}"= UDP:d:\games\MMORPGS\Turbine Download Manager\TurbineNetworkService.exe:TurbineNetworkService
"{16339C6B-F5F5-487D-A4A3-0A06B71CDC61}"= TCP:d:\games\MMORPGS\Turbine Download Manager\TurbineNetworkService.exe:TurbineNetworkService
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\PublicProfile]
"EnableFirewall"= 0 (0x0)
R2 ETService;Empowering Technology Service;c:\program files\EMACHINES\eMachines Recovery Management\Service\ETService.exe [10/10/2007 12:21 AM 24576]
R2 LiveTurbineMessageService;Turbine Message Service - Live;d:\games\MMORPGS\Turbine Download Manager\TurbineMessageService.exe [5/19/2009 9:55 PM 267760]
R3 LiveTurbineNetworkService;Turbine Network Service - Live;d:\games\MMORPGS\Turbine Download Manager\TurbineNetworkService.exe [5/19/2009 9:55 PM 218608]
S2 AxonService;Axon Virtual PBX;c:\program files\NCH Swift Sound\Axon\axon.exe [5/27/2009 11:17 PM 835588]
S3 scramby_out;Scramby Output;c:\windows\System32\drivers\scramby_out.sys [8/8/2007 8:31 AM 23840]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\svchost]
LocalServiceNoNetwork	REG_MULTI_SZ   	PLA DPS BFE mpssvc
- - - - ORPHANS REMOVED - - - -
HKLM-Run-eRecoveryService - (no file)
------- Supplementary Scan -------
uStart Page = hxxp://today.ask.com/frostwire?o=101676&l=dis
mStart Page = hxxp://homepage.emachines.com/rdr.aspx?b=ACEW&l=0409&s=1&o=vb32&d=1007&m=el1200-07w
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office12\EXCEL.EXE/3000
DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} - hxxp://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab
catchme 0.3.1398 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2009-06-23 03:09
Windows 6.0.6001 Service Pack 1 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
c:\users\Shaka\AppData\Roaming\Microsoft\Windows\Cookies\shaka@msn[1].txt
scan completed successfully
hidden files: 1
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_LOCAL_MACHINE\system\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
@Denied: (A) (Everyone)
@Allowed: (B 1 2 3 4 5) (S-1-5-20)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
------------------------ Other Running Processes ------------------------
c:\windows\System32\nvvsvc.exe
c:\windows\System32\audiodg.exe
c:\windows\System32\rundll32.exe
c:\windows\System32\agrsmsvc.exe
c:\program files\CyberLink\Shared files\RichVideo.exe
c:\windows\System32\WUDFHost.exe
c:\windows\System32\consent.exe
Completion time: 2009-06-23  3:12 - machine was rebooted
ComboFix-quarantined-files.txt  2009-06-23 10:12
Pre-Run: 33,226,846,208 bytes free
Post-Run: 34,376,314,880 bytes free
241
