Xfx gtx 260 b-e...
DSM1999
Guys, I just received my GTX260 but it doesnt come with the 6pin to 6pin cable, it comes with the 4pin molex to 6pin cable.
How can I do this.
I only have one 6pin to 6pin cable and the other cable is the one that came with the video card.
Do I just use the cable with the 2 x 4pin molex to 6pin only? or can I use the other one I have the 6pin to 6pin one?
kookooshortman55
What do you mean by a 6-pin to 6-pin cable? If your power supply has one 6-pin cable, use that for one of the required power ports. Then use the included adapter for the second power port, and plug in 2 molex cables into it. Just make sure your power supply is powerful enough to power the card.
DSM1999
oh so u can use two type of cables?
