Can i get a Quad-core build for 500 dollars?
giuseppe07
i have a 22" Samsung monitor
Thermaltake Xaser VI VG4000BNSB (Its really massive) If anyone wants to buy it i will sell it to them its just to big for me give you a good deal. Its Brand New I won it as a prize.
Mouse, Keyboard, Cd-rom
So I need a
CPU:
Motherboard:
PSU:
Graphic Card:
Ram:
Hard Drive:
I have made previous post but would like to know if a Quad-Core build will be possible for 500 dollars.
I went a little above 500 dollar budget but if you dont wanna pay 513 you can pick up hd 4830
CPU: Phenom X4 810 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103650
MOBO: GIGABYTE GA-MA770T-UD3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128392
RAM: G.SKILL 4GB DDR3 1333 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231200
GPU: Sapphire Radeon HD 4850 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102824
PSU: Raidmax 600w http://www.newegg.com/Product/Product.aspx?Item=N82E16817152041
HDD: Western Digital 500GB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
It all comes to $513.95
The 810 is not really worth it over a 720 tri core, as the 720 overclocks better, has more cache, etc. Plus raidmax psu's are notoriously unreliable.
Well he wanted a quad core so i gave him quad core :P
My friend has that psu and its been working flawlessly so far :x
Do you also have the two following components:
1) computer case
2) optical drive (DVD drive)
If you don't already have these you will need to purchase them as well to have a complete system.
1) computer case
Appears as if he does...:P
