Help me choose my ram (and others maybe too)...
erebusting
Ok I have been planing to build a new computer and I think it is finally coming into play - here is my setup so far ..
CPU: *Core i7 920
Mobo: *EVGA x58 Classified
PSU: *1000hx Corsair ?
Ram: ...something 2000 mhz, & good for overclocks and stability/longevity..hopefully no more than $200 give/take...
Case: *Cooler Master HAF
GPU: *BFG 295 GTX --not changeable, already have it...
CPU Cooler: *Cooler Master V8
I will be using my old hdd and dvd drives, and I have a 23" screen already....
You would recommend those over any others?...
..over some corsair dominators even? (do they even make those in 2000 mhz?)...
Yeah, for the price you cant beat it. The corsair dominators are over $400 and honestly, not worth it. G.skill, Mushkin, and Patriot are my preferred memory brands, and they are also pretty much the best imo.
I intend to overclock, do you believe they will perform well?...or should I look towards better ram if I am going to be overclocking...
I just want a smooth / VERY stable computer....
Yes, they are good memory. When overclocking all you'll need to do is set a memory divider so they run at around their right speed;) Personally id go with the mushkin over the g.skill, both are excellent memory and id recommend them 100%, but i feel mushkin is prolly the best memory made overall. Plus it has lower timings(for cas latency, lower=better)
what about G.Skill Perfect Storm?....
any real difference?
Hi erebusting,
Why did you ask us to refer that link. Don't you think that your post seems like spam. I don't know what you need to know from us. Please mention us clearly what you are searching for, so that we could help you.
Regards
Mike
well see first of all theres one comment about a CORSAIR PSU...then my comment, then another for a CORSAIR PSU...idk sorry anyways..
but now I really need help deciding on storage (ssd raid vs sas raid)..Motherboard (not sure if I should get the p6t7 ?...also maybe a good fan controller? (Id like an lcd if possible...is this one fine?:http://www.newegg.com/Product/Product.aspx?Item=N82E16811998055
I am considering these Parts so far other than what I listed above:
case: CM HAF Full
??ram: G.Skill perfect storm 2000mhz ...or should I get the crucial tracer ddr 3 ram? (run 6x1gb sticks ?) OR
THIS RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820220385 OR
THIS RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820220401 OR GO ALL OUT
WITH THIS:http://www.newegg.com/Product/Product.aspx?Item=N82E16820145237
hs: Scythe MUGEN-2
KB & M: G9 & G15
PSU : BFG 1200w..
HDD: 2x Fujitsu sas in raid 0...
GPU: BFG gtx 295 (already have it)
Please help, I need your advice!
