Can i get a Quad-core build for 500 dollars?
I would recommend this central processing unit, motherboard, power supply and RAM (I have no input presently on a video card):
AMD Phenom II 720 Tri-Core Processor - $119
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649
GIGABYTE GA-MA770T-UD3P Motherboard - $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128392
OCZ StealthXStream OCZ700SXS 700 Watt Power Supply - $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341019
Patriot Extreme Performance 2 gigabytes 240-Pin DDR3 1333 (PC3 10666) - $45
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220304
or if you really want 4 gigabytes of RAM
Patriot Extreme Performance 4 gigabytes 240-Pin DDR3 1333 (PC3 10666) - $72
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220305
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
SAPPHIRE 100245HDMI Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ... - Retail
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT - Retail
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard -
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core Black
how is this can i downgrade on the ram or do i need to get the ddr3 1333 or can i get ddr2 1066
ASUS M4A78 Plus AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard - Retail
OCZ StealthXStream OCZ600SXS 600W ATX12V / EPS12V SLI Ready Active PFC Power Supply - Retail
OCZ 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2G10664GK - Retail
AMD Phenom II X4 920 2.8GHz Socket AM2+ 125W Quad-Core Processor Model HDX920XCGIBOX - Retail
how is this will this work?
Personally id go with this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231241
Thats just an opinion though, if you prefer OCZ by all means go with the ocz. Other than that though, looks great. Id go with a 700W to provide enough power do do crossfire in the future if you want, $10 more before rebate and same price after rebate:
Well, ive had better experiences with G.Skill than OCZ(although both companies ddr2 is great), the G.skill has lower voltages and would run somewhat cooler than the ocz. Although since the ocz has free shipping it would be cheaper...
