cpu temps 101
ok so my idle temp for my cpu is about 108 degrees...is that hot or normal or wat?
thanks!
I'm assuming you're talking farenheight - or your CPU will be melting :eek:
Do you have a heatsink on it. Never run any CPU without a heatsink / fan.
42 degrees Celsius (108 Fahrenheit) is a good temperature for a central processing unit to run at. You have nothing to worry about.
The cores on my AMD Athlon 64 X2 5000+ (2.61GHZ) are ruuning at 72F and 80F with a 10% load right now. Been watching movies and surfing for several hours now.
